jakester
Jan 01, 2016Tutor
Rn314 no access past the boot up... "mount_block_root +1 e 9" huh? #26280310
The rn31400 ws up and running for a week,lovin it...Cannot login now, with any browser, having used correct password. Rebooted, shut it down, restart,no luck. Raidar did see the nas up to the time I ...
- Feb 02, 2016
We've been able to confirm that this is a problem that should always be fixable with USB Boot Recovery. Not all USB keys are compatible so you may need to try a number of USB keys before you find one that works.
Please see this article: ReadyNAS OS 6: LCD says mount_block_root+1e9
There is a fix to prevent further cases of this issue. It is in the 6.4.2 firmware update which is now available.
mdgm-ntgr
Jan 26, 2016NETGEAR Employee Retired
We are working on a fix to prevent further cases of this issue. It will be in an upcoming firmware update.
mdgm-ntgr
Feb 02, 2016NETGEAR Employee Retired
- advocate1Feb 02, 2016Guide
When I click "check for updates" on both of my ReadNAS 31400s, nothing happens.
Is this yet another bug, or is the 6.4.2 update not yet available?
- mdgm-ntgrFeb 02, 2016NETGEAR Employee Retired
We released it as a local update for now and it will be put on the update server later.
