scarygary71's avatar
scarygary71
RN314 read only file system
I've been using a RN314 for backup purposes for a bunch of years now and all of a sudden the filesystem is read only. As this is a backup system and the primary storage is still intact as well as the copy I'm sending to the cloud, I reformated the drives and recreated the volume. After about a week the same thing happened again. I have no idea where to start. I tried to attach the logfiles to the post, but the file upload only allows images and pdfs. Sharing it from onedrive instead.
https://1drv.ms/u/s!Ao2ngGbMNQkGuwkbYnX_t-ILu-xu?e=L3qmXG
  • StephenB's avatar
    You shouldn't post log files publicly, so please unshare your log zip.
    There are btrfs errors in the file system.
    May 25 00:43:06 nasbackup kernel: BTRFS error (device md127): parent transid verify failed on 3710532419584 wanted 17240 found 17882
    May 25 00:43:06 nasbackup kernel: BTRFS warning (device md127): Skipping commit of aborted transaction.
    May 25 00:43:06 nasbackup kernel: BTRFS: error (device md127) in cleanup_transaction:1864: errno=-5 IO failure
    May 25 00:43:06 nasbackup kernel: BTRFS info (device md127): forced readonly
    May 25 00:43:06 nasbackup kernel: BTRFS: error (device md127) in btrfs_drop_snapshot:9412: errno=-5 IO failure
    May 25 00:43:06 nasbackup kernel: BTRFS info (device md127): delayed_refs has NO entry
    I don't know what is causing them though.
    I am a bit confused on the reformatting statement, as there are some much older dates in the log zip. For instance, smart_history.log begins with
    2016-04-28 19:04:09  TOSHIBA DT01ACA200 ...
    Did you do a factory default?  Or just recreate the data volume?
    • scarygary71's avatar
      scarygary71
      I had no idea there was sensitive information in the log files. I unshared the file.
      I only recreated the data volume. I might have factory reset the nas a long time ago though. Probably years ago.
      I've replaced a few drives over the years.
      • Sandshark's avatar
        Sandshark
        Sensei
        Your NAS is having trouble communicating with one or more of the drives.  Are you seeing ATA errors recorded on any of them?  Note that the drive often will record an ATA error even if the problem is with the NAS, so don't jump to the conclusion a drive is bad.  That takes some more testing.
        Step one would be to (with power off) pull and re-seat all drives, checking the integrity and cleanliness of the connectors as you do so.  If the log doesn't point to a specific drive, doing the built-in drive test might.
ProSupport for Business
