synth54
May 20, 2022Aspirant
RN316 - Read Only status during resyncing task on EDA500 extension
Hi, I'm facing an issue with my NAS system, which is made of a RN316 and a EDA500 with mainly all 8TB HDD (except 2 10TB ones). The problem is : an error occured on the 3rd HDD of the EDA500 mod...
May 20, 2022Guru - Experienced User
synth54 wrote:
Resyncing task is still in progress, I don't know what to do.
Download the full log zip file now, as that will likely contain clues to what is happening with the main volume. If you have no backup of the main volume, then back it up while you are waiting for the resync to complete. Don't reboot the NAS until you complete the backup and the EDA500 resync completes.
At that point, I'd try rebooting the NAS, and see if the main volume remains read-only. I suspect it will (and it might not be mounted at all). But it is unusual that the read-only status was coincident with the EDA500 error, so it is possible that the main volume will end up read/write.
After that, you could either get a support contract with Netgear, and see if they can resolve the issue with the main volume remotely. Or you can try creating a new volume, and restore the files from your backup.
synth54 wrote:
I don't understand why the volume of the main device has a read-only status due to resyncing task of the extension
It's likely not related to the resync, but it might be linked to the EDA disk error somehow. You could look in the log zip, and see what underlying errors happened - but focus on completing/updating your backup first. The data is definitely at risk.
synth54
Dear Stephen,
thanks for your quick feedback.
I want to precise a point : "read-only" issue happened yesterday afternoon, and in the evening after downloading log files I decided to switch off the system, I rebooted it this morning with exactly the same symptom.
I’m currently trying to download a new log sip but the system seems to answer too slowly and transaction goes to error status.
Nevertheless I just had a look in the system-journal.log file (downloaded before the switch off) and I found that :
May 19 15:48:51 nas-27-5B-DE kernel: WARNING: CPU: 0 PID: 29160 at fs/btrfs/extent-tree.c:7004 __btrfs_free_extent+0xaf4/0xb31()
May 19 15:48:51 nas-27-5B-DE kernel: BTRFS: Transaction aborted (error -28)
May 19 15:48:51 nas-27-5B-DE kernel: Modules linked in: sx8635(O) vpd(PO)
May 19 15:48:51 nas-27-5B-DE kernel: CPU: 0 PID: 29160 Comm: kworker/u8:10 Tainted: P W O 4.4.218.x86_64.1 #1
May 19 15:48:51 nas-27-5B-DE kernel: Hardware name: NETGEAR ReadyNAS 316 /ReadyNAS 316 , BIOS 4.6.5 03/23/2013
May 19 15:48:51 nas-27-5B-DE kernel: Workqueue: btrfs-extent-refs btrfs_extent_refs_helper
May 19 15:48:51 nas-27-5B-DE kernel: 0000000000000000 ffff88002fe5fb28 ffffffff88364895 ffff88002fe5fb70
May 19 15:48:51 nas-27-5B-DE kernel: 0000000000000009 ffff88002fe5fb60 ffffffff880dd2dc ffffffff88283d5b
May 19 15:48:51 nas-27-5B-DE kernel: 00000000ffffffe4 ffff880078462620 ffff88007c2975a0 0000000000000000
May 19 15:48:51 nas-27-5B-DE kernel: Call Trace:
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88364895>] dump_stack+0x57/0x6d
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff880dd2dc>] warn_slowpath_common+0x8f/0xa8
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88283d5b>] ? __btrfs_free_extent+0xaf4/0xb31
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88063fb1>] warn_slowpath_fmt+0x47/0x49
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff8828334d>] ? __btrfs_free_extent+0xe6/0xb31
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88283d5b>] __btrfs_free_extent+0xaf4/0xb31
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff882e124b>] ? btrfs_merge_delayed_refs+0x5d/0x40f
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff882e0831>] ? find_ref_head+0x49/0x63
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88287887>] __btrfs_run_delayed_refs+0xa78/0xcbf
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff8828965e>] btrfs_run_delayed_refs+0x66/0x24f
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff8828989c>] delayed_ref_async_start+0x55/0x94
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff882c7d14>] btrfs_worker_helper+0xbb/0x175
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff882c7e87>] btrfs_extent_refs_helper+0x9/0xb
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88075578>] process_one_work+0x198/0x2b0
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88075f1e>] worker_thread+0x25f/0x348
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88075cbf>] ? rescuer_thread+0x263/0x263
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88079d6f>] kthread+0xdc/0xe4
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff88079c93>] ? kthread_worker_fn+0x129/0x129
May 19 15:48:51 nas-27-5B-DE kernel: [<ffffffff888e9caf>] ret_from_fork+0x3f/0x80
May 19 15:48:51 nas-27-5B-DE kernel: ---[ end trace e252aaa2fde32dee ]---
May 19 15:48:51 nas-27-5B-DE kernel: BTRFS: error (device md126) in __btrfs_free_extent:7004: errno=-28 No space left
May 19 15:48:51 nas-27-5B-DE kernel: BTRFS info (device md126): forced readonly
May 19 15:48:53 nas-27-5B-DE kernel: BTRFS: error (device md126) in btrfs_run_delayed_refs:2995: errno=-28 No space left
May 19 15:48:53 nas-27-5B-DE minidlnad[3570]: [matroska,webm @ 0x7f0004042260] Read error at pos. 3369256917 (0xc8d2c7d5)
May 19 15:48:55 nas-27-5B-DE minidlnad[3570]: sql.c:41: error: SQL ERROR 10 [disk I/O error]
It seems that system considers the volume complety full, even if we can see 1.7TB left on web interface page.
I can easily remove 1TB of Data but as the volume is read only stated I can't.
Remark : I'm reluctant to upload complete log zip as there are some confidential files and data on the NAS and as I don't know what is listed in the log files I prefer to copy some elements. Nevertheless please find downloaed the system-journal.log file in PDF as log extension has been rejected by the system.
Regarding resyncing task, in the same file I see start of the problem earlier in the day (yesterday) :
May 19 10:28:03 nas-27-5B-DE rn-expand[4864]: Partitioning failed! [2]
That means both are not linked ! We have the answer of one question and probably I will have to replace one HDD.
Now remaining question is related to the read-only state and how to make space free under this condition.
Thanks for your understanding and support
