ovidiu
Feb 20, 2019Aspirant
RN316 soaped one drive and all volume is unreadable and HDD's are in red
I wanted to exchange the HDD's, because it showed degraded, but I had access to all the data.
In theprocess, I put a brand new WD RED 8TB, that prooved to be defective and I RMA-ed it.
I put it ...
- Feb 20, 2019
A degraded volkume with all "healthy" drives usually means the volume is out of sync. Until it's back to healthy, replacing a drive is not a good idea and replacing anything except the one that's out of sync is a disaster.
I'm not sure if you did actually replace the wrong drive at one point or if the (quite drive intensive) sync process pushed another drive over the cliff, but I agree it sounds like you are in file recovery territory.
ovidiu
Thank you Stephan for your input.
Just before you replyed I panicked, and put back th original HDD1 (that were before the mishap with the defective 8TB). it's resyncing now, and what is annoying is that the system is described as Healthy but dead.
My Linux skills are abysmal at best, I can follow instructions like a monkey maybe, because I was used to DOS, but not familiar to Linux).
I can make a live Linux USB, and I do have 1 or 2 SATA internal cables on my Win machine.
Nothing was really written on the Hdd's ecept the re-syncing steps. Are there any chances of recovering the data?
Feb 20, 2019Guru - Experienced User
ovidiu wrote:Just before you replyed I panicked, and put back th original HDD1 (that were before the mishap with the defective 8TB).
This could have done more damage - potentially destroying your ability to recover the data. Hopefully it didn't. Don't do this with the other hard drive you removed.
Re-syncing a newly inserted drive writes something to every sector on it. That destroys everything that was on it before.
- ovidiuFeb 20, 2019Aspirant
I see, I might have diminshed the chances. Well, regarding the other hard-drive, that one was first put back at 10PM last night, when they all became color red, so basically it's in the initial "degraded" working configuration.
So I might have messed out more... hmm..
The "Status Healthy" message was confusing, and all HDD show nicely green dots and temperatures. So I assummed just that the degraded was just a SMART code for some minimal [roblem.
What was interesting, was that I was able to swap drives that resynced in that degraded state. SoI got encouraged and to change the disks with the smart ATA error code (showing only byhoovering over the bih NAS icon in WebUI.
Because the Deagates Showed no ATA eror I was expecting to fix the "degraded" message, Tha apppearead after I tried that unfortunatelly defective new WD Red.
In 6 hours thr resyncyng will be done.
What would be the best course of action.?
- StephenBFeb 20, 2019Guru - Experienced User
Well, stop manipulating disks and look into data recovery.
Netgear offers a service: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service If you can connect all the disks to a Windows PC (USB adapters/dock is ok), then you could try ReclaiMe: https://www.reclaime.com/
- SandsharkFeb 20, 2019Sensei
