Steedvlx600
Jun 04, 2019Luminary
RN316 Stuck at Booting 99% immediately after firmware update
I am desperately seeking a solution to this issue. I updated the firmware on my RN316 a few days ago. I had not used the admin panel on the NAS since that time. But, I booted it today and, the adm...
- Jun 06, 2019
Steedvlx600 wrote:
The data would be in a home share with its own user account.
Ok. Then if you can access the NAS volume with finder using the NAS admin credentials you'd see a home folder in volume. Inside that you should see the home share. It would be possible to move the files into a new share, which would give you access.
Though something clearly is corrupted (since the account went missing). So Netgear support is probably the safest avenue.
Steedvlx600
Tried using RAIDar to reboot. Now, it is stuck in the early stages of booting. Before the progress bar starts displaying.
- StephenBJun 05, 2019Guru - Experienced User
Try doing an OS reinstall from the boot menu.
- Steedvlx600Jun 06, 2019Luminary
OK, I did that. Now, after some acrobatics, I have my admin panel back.... BUT... My user account is missing!!!
The space available is correct. So, the files are still there. But how do I restore my user account without losing my files?
- StephenBJun 06, 2019Guru - Experienced User
Can you see the files if you access the data volume with NAS admin credentials?
For instance, from the Windows CMD window
net use * /delete net use t: \\nas-ip-address\Data /user:admin nas-admin-password
Substitute your actual volume name if you use flexraid. Be careful on the typing - especially slash direction and spaces.
The first command terminates any open network sessions - if it prompts for confirmation, let it proceed.
The second command mounts the data volume as drive letter T.
If this works, then back up your files.
