Steedvlx600
Jun 04, 2019Luminary
RN316 Stuck at Booting 99% immediately after firmware update
I am desperately seeking a solution to this issue. I updated the firmware on my RN316 a few days ago. I had not used the admin panel on the NAS since that time. But, I booted it today and, the adm...
- Jun 06, 2019
Steedvlx600 wrote:
The data would be in a home share with its own user account.
Ok. Then if you can access the NAS volume with finder using the NAS admin credentials you'd see a home folder in volume. Inside that you should see the home share. It would be possible to move the files into a new share, which would give you access.
Though something clearly is corrupted (since the account went missing). So Netgear support is probably the safest avenue.
Jun 09, 2019Guru - Experienced User
Thx for pulling together the info for all the steps.
Steedvlx600
Jun 09, 2019Luminary
I jotted down as much as I could remember - before I forgot it.
