Diggers
Dec 03, 2021Aspirant
RN516 - Boot Loop after power outage
Hi, I have a Readynas 516 thats now stuck in a boot loop after a power outage. The box starts up, displays Welcom on the LCD, the touchpad lights up, then it reboots, the cycle is around 2-3 seco...
Dec 04, 2021Guru - Experienced User
Have you tried removing the disks (labeling by slot), and then power up? Just to see if the loop is somehow disk-related?
- SandsharkDec 04, 2021Sensei
Try booting without drives first. If that works, it's unlikely a USB recovery id going to help.
But I did see a similar symptom that was cured by a USB recovery. The 516's with the latest BIOS (like the one I saw it on) don't need you to play tag with the button to boot from USB, so it was easy for me. If yours is older, then I think it's just a matter of multiple tries till you somehow get it right. Netgear obviously recognized there was a problem with that USB recovery scheme and fixed it in the later BIOS, but loading a new BIOS was not made available because, as I understand it, what version you came from made a difference as to the process needed.
- DiggersDec 04, 2021Aspirant
Thanks for the reply,
Yep, i have tried pulling the drives but i still get the same result, the LCD displays "Netgear storage welcome" then the touch pad lights up for 2-3 seconds, then it repeats, and the fan is at full speedthe whole time.
I have a usb stick with an LED, and it flashes once quickly when first inserted but then nothing there after, not even on the next loop, only when first inserted.
I have seen a few people have had a similar experience, any ideas on what the cause may be? i have tested the power supply and all output voltages look to be within tolerance, not that that rules out an issue on current draw.
Would a fault with the RAM cause this kind of issue? or is it likely something else?- DiggersDec 04, 2021Aspirant
I've managed to connect to the UART on the back, Can anyone confirm the pinouts on the 516? Ive currently found pins 1 & 2 to be TX and RX
Using Putty im receiving the following:
"ERROR: Type:2; Severity:80; Class:3; Subclass:2; Operation: 1000"
Any ideas as to what the error message is pointing to?
- DiggersDec 06, 2021Aspirant
Is there a document available anywhere that lists the error codes for the readynas 516?
