Diggers
Dec 03, 2021Aspirant
RN516 - Boot Loop after power outage
Hi, I have a Readynas 516 thats now stuck in a boot loop after a power outage. The box starts up, displays Welcom on the LCD, the touchpad lights up, then it reboots, the cycle is around 2-3 seco...
Diggers
Dec 04, 2021Aspirant
Thanks for the reply,
Yep, i have tried pulling the drives but i still get the same result, the LCD displays "Netgear storage welcome" then the touch pad lights up for 2-3 seconds, then it repeats, and the fan is at full speedthe whole time.
I have a usb stick with an LED, and it flashes once quickly when first inserted but then nothing there after, not even on the next loop, only when first inserted.
I have seen a few people have had a similar experience, any ideas on what the cause may be? i have tested the power supply and all output voltages look to be within tolerance, not that that rules out an issue on current draw.
Would a fault with the RAM cause this kind of issue? or is it likely something else?
Diggers
I've managed to connect to the UART on the back, Can anyone confirm the pinouts on the 516? Ive currently found pins 1 & 2 to be TX and RX
Using Putty im receiving the following:
"ERROR: Type:2; Severity:80; Class:3; Subclass:2; Operation: 1000"
Any ideas as to what the error message is pointing to?
- DiggersDec 06, 2021Aspirant
Is there a document available anywhere that lists the error codes for the readynas 516?
- StephenBDec 06, 2021Guru - Experienced User
Not that I know of.
Perhaps JeraldM can interpret it for you???
- JeraldMDec 07, 2021NETGEAR Employee Retired
Thanks for the ping, StephenB.
Hi Diggers,
Based on the error message, it looks like an error with the software, specifically its PEI Core.
Not quite sure though if that's the main cause of the issue, that being said, are there any other logs when you were connected via Putty?
JeraldM
NETGEAR Community Team
