Diggers
Dec 03, 2021Aspirant
RN516 - Boot Loop after power outage
Hi, I have a Readynas 516 thats now stuck in a boot loop after a power outage. The box starts up, displays Welcom on the LCD, the touchpad lights up, then it reboots, the cycle is around 2-3 seco...
Diggers
Dec 04, 2021Aspirant
I've managed to connect to the UART on the back, Can anyone confirm the pinouts on the 516? Ive currently found pins 1 & 2 to be TX and RX
Using Putty im receiving the following:
"ERROR: Type:2; Severity:80; Class:3; Subclass:2; Operation: 1000"
Any ideas as to what the error message is pointing to?
Diggers
Dec 06, 2021Aspirant
Is there a document available anywhere that lists the error codes for the readynas 516?
- StephenBDec 06, 2021Guru - Experienced User
Not that I know of.
Perhaps JeraldM can interpret it for you???
- JeraldMDec 07, 2021NETGEAR Employee Retired
Thanks for the ping, StephenB.
Hi Diggers,
Based on the error message, it looks like an error with the software, specifically its PEI Core.
Not quite sure though if that's the main cause of the issue, that being said, are there any other logs when you were connected via Putty?
JeraldM
NETGEAR Community Team
- SandsharkDec 07, 2021Sensei
Unless "PEI" has some unique meaning here, it's "Pre EFI initialization", which is a BIOS function prior to it even looking for something to boot from. PEI Core is typcially before it even checks memory. But maybe it's saying that's the last thing that did complete, and it is a memory issue.
