nickjames
Oct 17, 2025Luminary
RN516 finally EOL?
I thought the RN516 went EoL quite some time ago... but I had still be updating the firmware over the years and I still got antivirus definitions for it too. Back on September 29th, the antivirus def...
- Oct 18, 2025
The RN516 went EoL in 2017. Netgear exited the NAS business, and now all ReadyNAS platforms are now EoL.
While Netgear announced the end of firmware updates for NAS running 4.1.x, 4.2.x, and 5.3.x when those updates ended, they did not announce end of firmware updates for OS-6. Personally I think that is a mistake - a NAS is very different product from a router or switch.
In any event, I expect that 6.10.10 will be the final firmware release.
nickjames wrote:
Back on September 29th, the antivirus definitions started failing daily.
The version of ClamAV that Netgear distributed (0.103) became end-of-life in 2024. ClamAV began blocking definition updates to that version in September 2025.
- https://blog.clamav.net/2024/08/clamav-0103-lts-end-of-life-announcement.html
- https://docs.clamav.net/faq/faq-eol.html#version-support-matrix
Netgear built this package from ClamAV source, and they have told me that they have no plans to update it.
broy55
Mar 09, 2026Aspirant
For anyone still interested in using the old Netgear Readynas RN516 with something like Open Media Vault, I found a way to fix the annoying SMI boot that resets every time you shutdown the NAS. I used Google Gemini to help me with this, but basically it involves installing Clover on the SMI chip. First, you need to install Debian on a flashdrive and tell the Bios to boot the flash drive. Once you SSH into the NAS follow these steps.
apt-get update
apt-get install p7zip-full -y
cd /tmp
wget https://github.com/CloverHackyColor/CloverBootloader/releases/download/5170/Clover-5170-X64.iso.7z
7z x Clover-5170-X64.iso.7z
umount /dev/sdh* 2>/dev/null
dd if=Clover-5170-X64.iso of=/dev/sdh bs=4M status=progress
sync
Once that's complete, you RN516 will not boot to your external USB device everytime. No more having to change the boot in the bios when you shutdown the NAS. I haven't tested yet, but I imagine this would also allow you to use the first drive bay as a boot drive. I have OMV installed on my RN516 and now I can run docker and various plugins, especially if you upgrade the CPU and RAM.
broy55
Mar 10, 2026Aspirant
I should have mentioned that you need to check the dev of the SMI before running the script. Mine was sdh, but yours could be different.
