Perbor
Oct 19, 2022Aspirant
RN51600 - get memory error on startup
Hi My ReadNAS cannot start, can´t even reach the boot menu. Display says Memory Error. Anyone that has suggestions? Could it be physical memory? Anyone that knows what memory to buy and how to rep...
Perbor
Oct 20, 2022Aspirant
Thanks for the input and the links!!
Seems the Crucial memory is hard to find in Sweden, it is orderable to Sweden from USA but that takes a while and the freight is more than cost of the memory.
What I can find in Sweden are used DDR3L-RDIMM-8GB-12800R ECC memories, sold with 12 month warranty. Anything to consider or should I go for the longer devliery?
Oct 20, 2022Guru - Experienced User
You do want to make sure it is unbuffered ECC memory.
Also I'd check availability of 4G modules also, as the suggestion to go with 8 GB was based on the small cost difference in the US.
- SandsharkOct 20, 2022Sensei
The "R's" in "DDR3L-RDIMM-8GB-12800R ECC" mean "registered", aka buffered, so that won't work. You want DDR3L-12800E, though sometimes the E is omitted and it just says ECC Unbuffered and is sometimes also labeled as a UDIMM.
It's not uncommon, a lot of HP and Lenovo servers used it, and I know of no reason a specific brand would be better than another.
- PerborOct 21, 2022AspirantThanks for all advice!
I found a used memory at low cost and fast delivery ” HP 4GB DDR3 PC3-12800E ECC UDIMM”
Hope I got all params correct.- SandsharkOct 22, 2022Sensei
Looks right to me.
- PerborOct 26, 2022Aspirant
I got the memory, installed but the memory error remains. 😞
Anyone with any suggestions?
- SandsharkOct 27, 2022Sensei
I've never tried booting a 516 with just one memory stick, but you could try it.
