Hmarrero
Sep 28, 2018Aspirant
RN524x Memory Upgrade
Looking for some help on compatible memory for my ReadyNas 524x. I know it suggest DDR4 UDIMM ECC, I went to my local Microcenter and they told me it some type of special memory, has any one upgrade...
- Oct 03, 2018
Hi Hmarrero
It shouldn't damage the board but the performance might be degraded or it might not boot up. That is why it is always advised to perform Memory tests.Unfortunately we have not performed any tests regarding memory modules so we really cannot say if it is compatible or not :(
Hope we have helped in anyway, we encourage you to mark our reply as accepted solution if it fits :)
Marc_V
Oct 03, 2018NETGEAR Employee Retired
Hi Hmarrero
