jimk1963
Dec 21, 2022Virtuoso
RN528X Disk Error (1 of 8 drives) using X-Raid… what next?
Running 8 Toshiba 4TB SATA drives. observed an error on Disk 4, photos below describe what I see. Questions: 1) Do I need to replace the drive? 2) If not, is there some other "fix" I should try ...
Dec 21, 2022Guru - Experienced User
jimk1963 wrote:
Questions:
Looks like it. There might be more information in the logs, but this looks like a usual disk failure. You could power down, connect the disk to a Windows PC (SATA or USB) and confirm. Though I don't think Toshiba has a test utility. Seatools or WD's dashboard software might be able to test it.
While you can still find them for sale, these are old drives - the current Toshiba models would be the N300 or the N300 Pro. You could also replace it with another enterprise class drive - or possibly a WD Red Plus/Pro or Ironwolf (regular or Pro).
jimk1963 wrote:
3) I recall doing full rebuilds takes a very long time (on another ReadyNAS where I upgraded the drives), and also is "risky" for losing data. So am not keen on that... I think?
The resync will take a little while - you have 32 TBs of raw disk space, and every sector will need to be either read or written. Hard to say exactly how long, but I would guess 24-48 hours for RAID-6.
But there really is no other option. Even if rebooting brought it back to life (unlikely) , would you still trust it?
Netgear does recommend making a backup first - and personally I always recommend having up to date backups for your NAS. RAID isn't enough to keep your data safe.
That said, you do have more protection than most, since you are running RAID-6. Even if a second disk were to fail in the middle of the resync, you should still avoid data loss.
- jimk1963Dec 21, 2022Virtuoso
Is it safe to just do this:
1) Power down NAS
2) Pull Disk 4 (bad drive)
3) Insert new Disk 4 (WD Red Plus or Ironwolf - presumably doesn't have to be 4TB but probably will stay with that)
4) Power on NAS
What happens on power-up? Will NAS automagically resync? System says 8.54TB is used and 13.26TB is free.
Sounds like you're saying, prior to this, back up the entire NAS somewhere (One or both of my other 2 NAS drives I guess)?
Thanks for the help!
- StephenBDec 21, 2022Guru - Experienced User
1) Power down NAS
4) Power on NAS
This will work, but I generally advise people to hot-swap (pull disk and replace it with NAS running).
Thanks, will hot swap after backing everything up. Last question, any concern if I swap the 4TB bad drive with a larger one, say 16TB or so? Just looking online, it's more cost-effective to purchase a larger drive but I'm not sure if X-RAID (RAID 6 I think) has any qualms with this? Spec sheet says RN528X has 80TB disk capacity, so I'm nowhere near busting that limit.
