BobFord
Apr 05, 2018Aspirant
RN628X Access Problems
There has been a related thread (https://community.netgear.com/t5/New-to-ReadyNAS/ReadyNAS-628X-Problems/m-p/1539239/highlight/false#M16065) which is now resolved and is closed However, the problem l...
Apr 05, 2018Guru - Experienced User
I suggest PM mdgm-ntgr; asking him if he is willing to look at the logs.
If you still have 90 day support available, you might want to try using that (my.netgear.com).
- BobFordApr 05, 2018Aspirant
Thanks Stephen
I've contacted support at my.netgear.com as suggested given the device is only 2 months old
StephenBwrote:I suggest PM mdgm-ntgr; asking him if he is willing to look at the logs.
- mdgm-ntgrApr 12, 2018NETGEAR Employee Retired
Your hostname has an underscore in it. Can you try changing the hostname to one without an underscore?
