BobFord
Apr 05, 2018Aspirant
RN628X Access Problems
There has been a related thread (https://community.netgear.com/t5/New-to-ReadyNAS/ReadyNAS-628X-Problems/m-p/1539239/highlight/false#M16065) which is now resolved and is closed However, the problem l...
Apr 05, 2018Guru - Experienced User
I suggest PM mdgm-ntgr; asking him if he is willing to look at the logs.
If you still have 90 day support available, you might want to try using that (my.netgear.com).
BobFord
Thanks Stephen
I've contacted support at my.netgear.com as suggested given the device is only 2 months old
StephenBwrote:I suggest PM mdgm-ntgr; asking him if he is willing to look at the logs.
- mdgm-ntgrApr 12, 2018NETGEAR Employee Retired
Your hostname has an underscore in it. Can you try changing the hostname to one without an underscore?
