pcha
Apr 09, 2019Aspirant
RND-4D Error: add_dirent_to_buf+11c
Dear all,
We have a NAS RN10400 and it is shows on the screen Error: add_dirent_to_buf+11c . We have tried to reset it, reinstall OS, USB recovery and everything has failed. Is someone ...
Apr 09, 2019Guru - Experienced User
What firmware are you running?
One thing you can try is removing all the disks (labeling by slot), and then doing a fresh factory install onto a scratch disk (not part of the array). The disk will be formatted, so anything on it will be lost.
The OS reinstall doesn't reinstall the full OS onto the hard drives. Doing a from-scratch install will tell us whether this problem is in the chassis (including the flash) or a corrupted OS partition on the drives.
pcha
Dear StephenB,
We don't kanow the firmwasre version since we have not updated the NAS for more than 2 years and unfortunately we have no access to the system.
I installed a different HDD and I am getting the same errors when I am asking for the factory default settings.
That is the console results.
BootROM 1.08
Booting from NAND flash
General initialization - Version: 1.0.0
High speed PHY - Version: 2.1.4 (COM-PHY-V20)
Update PEX Device ID 0x6710
High speed PHY - Ended Successfully
0001
DDR3 Training Sequence - Ver 5.7.1
DDR3 Training Sequence - Run without PBS.
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
__ __ _ _
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2011.12-gec25d27-dirty (Oct 26 2015 - 16:56:14) Marvell version: v2011.12 2014_T2.0p1
06/23/2015 ReadyNAS-104 V2.0
Board: DB-88F6710-BP
SoC: MV6710 A1
CPU: Marvell PJ4B v7 UP (Rev 1) LE
CPU @ 1200 [MHz]
L2 @ 600 [MHz]
TClock @ 200 [MHz]
DDR @ 600 [MHz]
DDR 16Bit Width, FastPath Memory Access
DRAM: 512 MiB
Map: Code: 0x1feef000:0x1ff9f514
BSS: 0x1ffef8a0
Stack: 0x1f9eeef8
Heap: 0x1f9ef000:0x1feef000
NAND: (ID 0xf1ad) 128 MiB
MMC: MRVL_MMC: 0
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x000000080000
nand_read_bbt: Bad block at 0x000007d60000
Initialize and scan all PCI interfaces
PEX unit.port(active IF[-first bus]):
PEX 0: Root Complex Interface, Detected Link X1, GEN 2.0
PEX 1: Root Complex Interface, Detected Link X1, GEN 2.0
FPU not initialized
USB 0: Host Mode
USB 1: Host Mode
Shutting down unused interfaces:
SDIO
AUDIO
TDM
Modules/Interfaces Detected:
RGMII0 Phy
RGMII1 Phy
PEX0 (Lane 0)
PEX1 (Lane 1)
SATA0 (Lane 2)
SATA1 (Lane 3)
Net: egiga0
Warning: egiga0 MAC addresses don't match:
Address in SROM is 28:c6:08:35:a1:62
Address in environment is 28:c6:08:00:35:a1
, egiga1 [PRIME]
Power On!
FDT loaded successfully
Saving Environment to NAND...
Erasing Nand...
Writing to Nand... done
Enter Bootmenu...
Bootmenu : NORMAL
Bootmenu : FACTORY_DEFAULT
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x200000, size 0x400000
4194304 bytes read: OK
NAND read: device 0 offset 0x800000, size 0x400000
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux-4.4.140.armada.1
Created: 2018-07-17 15:56:09 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3478912 Bytes = 3.3 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: initramfs
Created: 2018-09-02 7:12:34 UTC
Image Type: ARM Linux RAMDisk Image (lzma compressed)
Data Size: 3390695 Bytes = 3.2 MiB
Load Address: 00000000
Entry Point: 00000000
## Flattened Device Tree blob at 01000000
Booting using the fdt blob at 0x01000000
Loading Kernel Image ... OK
Loading Ramdisk to 1f6b2000, end 1f9edce7 ... OK
Using Device Tree in place at 01000000, end 010068e5
Updating device tree successful
Starting kernel ...
Starting the boot process...
Detected system type: RN104
Loading kernel modules...done
Boot mode: Factory Default
UBI device number 0, total 919 LEBs (116690944 bytes, 111.3 MiB), available 9 LEBs (1142784 bytes, 1.1 MiB), LEB size 126976 bytes (124.0 KiB)
Segmentation fault
Segmentation fault
Bringing up network...done
Factory default, waiting for backup/ok button confirmation....done, timer stopped.
You asked to do a factory default!
Stopping running RAID devices...done
Creating partitions based on ST500LM030-2E717D (465GB) disk...sda.Segmentation fault
Segmentation fault
done
Creating root filesystem...done
Extracting root image...[ 47.325913] Internal error: Oops: 17 [#1] SMP ARM
[ 47.433518] Modules linked in: vpd(PO)
[ 47.437316] CPU: 0 PID: 1061 Comm: tar Tainted: P O 4.4.140.armada.1 #1
[ 47.445094] Hardware name: Marvell Armada 370/XP (Device Tree)
[ 47.450954] task: df225f80 ti: da0aa000 task.ti: da0aa000
[ 47.456381] PC is at add_dirent_to_buf+0x11c/0x1e4
[ 47.461195] LR is at 0x65636976
[ 47.464354] pc : [<c01504b4>] lr : [<65636976>] psr: 60000013
[ 47.464354] sp : da0abe20 ip : 00000014 fp : d46ba000
[ 47.475883] r10: da0abec4 r9 : 00001000 r8 : d46ba0d8
[ 47.481131] r7 : d46ff020 r6 : d46fea00 r5 : 00000000 r4 : 00000000
[ 47.487688] r3 : 0000000c r2 : 00000000 r1 : d4682c18 r0 : 00000000
[ 47.494246] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 47.501415] Control: 10c5387d Table: 19184019 DAC: 00000055
[ 47.507188] Process tar (pid: 1061, stack limit = 0xda0aa218)
[ 47.512961] Stack: (0xda0abe20 to 0xda0ac000)
[ 47.517344] be20: da0abec4 da0abec4 da0abe60 d46ff020 d46fea00 d46ff020 c068f3d3 d46e51b8
[ 47.525563] be40: d46e51b8 00000000 da0abeac d46e51b8 da0abeac d46ff020 d46ba000 c015072c
[ 47.533781] be60: c3a58b60 d46fea00 00000018 da0abf50 c39c3020 d46ba0d8 d4682be0 c00db714
[ 47.541999] be80: daeb6800 00001000 00000001 00000000 daeb6800 c39c3020 df12b000 00000000
[ 47.550219] bea0: d4682be8 d46fea00 d4682be8 dedf44c0 c39c3020 c39c3020 d4682be8 c00e834c
[ 47.558438] bec0: 00000000 d4682bf8 d4682c0c 0000000c 238e8980 ba969f3a 00000004 dad8f4a8
[ 47.566657] bee0: da0abf50 d46ba0d8 d46ff020 d4682be0 d46ff020 d46e51b8 d4682be0 df12f010
[ 47.574876] bf00: d46ba000 c01510f8 d46ba0d8 d46ff020 00000000 0000001c d46e51b8 c01530b0
[ 47.583095] bf20: 00000000 00000000 00000004 00000c34 00000023 00000000 d46e51b8 d46e51b8
[ 47.591313] bf40: 00000000 d4682be0 df12f010 01994180 ffffff9c 00000000 00000000 c00e00b0
[ 47.599532] bf60: d46e51b8 d4682be0 df12f010 01994060 df12f000 d4682be0 00000000 c00e1290
[ 47.607751] bf80: df1e7d10 dedec980 01994180 01994060 01994008 01994194 00000053 c000ece4
[ 47.615969] bfa0: da0aa000 c000eb20 01994060 01994008 019952c8 01994180 0000a1ff 0000a000
[ 47.624188] bfc0: 01994060 01994008 01994194 00000053 0000271e 00000000 b6f8ff70 00000000
[ 47.632406] bfe0: 000867a4 beb5ba38 0003f9cc b6f10d9c 60000010 019952c8 00000000 00000000
[ 47.640635] [<c01504b4>] (add_dirent_to_buf) from [<c015072c>] (ext4_add_entry+0x1b0/0xb68)
[ 47.649028] [<c015072c>] (ext4_add_entry) from [<c01510f8>] (ext4_add_nondir+0x14/0x58)
[ 47.657074] [<c01510f8>] (ext4_add_nondir) from [<c01530b0>] (ext4_symlink+0x230/0x2fc)
[ 47.665126] [<c01530b0>] (ext4_symlink) from [<c00e00b0>] (vfs_symlink+0xb8/0x128)
[ 47.672739] [<c00e00b0>] (vfs_symlink) from [<c00e1290>] (SyS_symlinkat+0x60/0xac)
[ 47.680355] [<c00e1290>] (SyS_symlinkat) from [<c000eb20>] (ret_fast_syscall+0x0/0x40)
[ 47.688314] Code: e1a00004 ebffff89 e3500000 bafffff5 (e594101c)
[ 47.694514] ---[ end trace e828e217a1441b4e ]---
[ 47.699157] Kernel panic - not syncing: Fatal exception
[ 47.704411] ---[ end Kernel panic - not syncing: Fatal exception
