gper56
Apr 27, 2022Aspirant
RND4000 Stuck at 13% when booting
Hi The device is out of warranty. Serial number 23J5197M00AFE So far I have attempted testing drive to see if that gets any results. They all appear to be good. I have reinstalled the OS - still ...
- May 14, 2022
Eventually got to the Factory reset stage.
This worked but disk 2 showed as failed which may have been the problem all along but no other evidence.
Replaced the disk a did another Factory reset and all came back golden. 🙂
Did full Shutdown restart to find that disk 2 reported as dead. 😞
tried a couple of other disks in Slot 2. They also reported dead. Beginning to suspect that Slot 2 is faulty.
Tried another disk and it is now syncing.
I think that slot two may be playing up so will see how it goes with the thought that is has gone past its best and needs replacing.
gper56
Apr 29, 2022Aspirant
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 2.0G 546M 1.5G 28% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 5.5T 3.7T 1.8T 68% /c
So its not the OS partition being full that is the problem.
A MOD has found that one of the disks has failed so i'm going to try a replacement and see what happens.
gper56
May 14, 2022Aspirant
