JasonJMan
Dec 08, 2019Aspirant
RND4000 V1 Mac No Front View For Shares & Admin Use
Hi there,
So I have a RND4000 V1 which has worked for a while now with no problems. I have now got the unit back up and running on my Mac after being in rented accomodation etc with no internet bla bla bla whilst my house was being built. All is good with the above unit for access etc until I wanted to access Front View to remove an old share etc. When I open RAIDar it sees my unit, all drives are good and yet when I click the admin page part as I have done many times before it loads the screen with nothing visible in the way of shares, admin stuff for powerdown etc etc.
I am on a Mac, use Safari, have tried this in Chrome too with no success and I am out of my depth knowledge wise what to do. I have a large amount of data on the drive which clearly I do not want to lose transferring that data to another drive would mean buying another very large drive to do so and robably have to wait days for the transfer to happen too :-( :-(
Any ideas out there to help me out??
Many thanks in advance
Jason
PS I am a newbie so please be gentle with me :-D
- SandsharkSensei
Do you see anything from the NAS? If not, check what IP address the NAS shows in RAIDar and insure it's in the same subnet (same first theee numbers) as your computer. Changing homes (and often routers with it) can cause issues if you assigned the NAS a fixed address.
How old is the OS version on the NAS? If you see just the border of Frontview, and not much more, there was an issue with updated browsers a long time ago, but that's long since fixed in OS updates.
- JasonJManAspirant
Hi there,
I can see everything on my NAS using a log in however what i am unable to do is any form of admin work - remove shares, add shares etc etc.
RAIDar sees the NAS and confirms an IP address - this I can use to connect to via my Mac.
If I try to access the admin part of Frontview I can see the actual webpage, surrounding yellow lines and picture of a NAS drive yet no words down the left hand side of this box where the Power, Shutdown, Shares etc tabs would be.
Hope that makes sense?I have attached a screenshot showing what I mean... Sorry for the delay been in work and just got home.
Thanks for your reply too :-)
Here's hoping you know what to do :-)
J
- SandsharkSensei
Yeah, I thought that might be what you are seing, because I once saw it, too. My issue was a corrupt configuration file, but I believe a full OS partition can also cause it. The problem with that issue is that if you don't already have SSH enabled, then you're in a Catch 22, since you can't enable SSH without access to Frontview. I was lucky enough to have SSH already enabled and one of the old "Jedi" helped me figure out the cause. I frankly don't remember which file it was that was bad, except it was something.conf.
If you are adept at the Linux console, maybe somebody other than me can lead you to where to look via the remote support portal. that boots off the flash, not the drives, and likely still works. It's just been too long since I ran an OS 4.x system for me to give more specific help. Well, that and the fact that I was much more a noob at that point and was following instructions more than knowing what I was doing in SSH.
