bmcdonald666
May 31, 2019Aspirant
RND4000 v3 not powering on - what should I buy to replace it so my harddrive data can be recovered
My ReadyNAS RND4000v3 no longer powers up. I asssume my four 2Tb Hard Drives are still good and I want to recover the data on there. Is there another model (current) that will simply allow me to slo...
- Jun 17, 2019
bmcdonald666 wrote:
If I insert my 4 s 2TB Hard-drives in to it in the same order as my RND4000 will my data be accessible?
Yes, you can directly migrate the drives.
First install a spare disk into the replacement NAS. Any SATA drive <= 2 TB will work for this. After the factory install completes, update the firmware in the replacement to match your existing NAS. If you don't know the firmware you are running, then install the latest (4.1.16).
Then try booting the replacement with the disk installed in each bay - just to make sure that all the bays are functional.
After that, power down and migrate the drives. All the settings are preserved (the operating system and configuration files on the drives), and your data will be available (unless something was corrupted when your current NAS failed).
bmcdonald666
Jun 17, 2019Aspirant
Hello
Ok so the RND4210 is the same model. If I insert my 4 s 2TB Hard-drives in to it in the same order as my RND4000 will my data be accessible? I am hoping it will just recognise everything as it was before my RND4000 decidied it no longer wants to power-up. I do not want to loose my data.
Jun 17, 2019Guru - Experienced User
