RogierP
Feb 22, 2016Aspirant
RND4210 Powerunit defect, will disks with data work in RNDP2000?
Hi, i have a RND4210v3 where the powersupply got smokked. I have a spare RNDP2000. Will this NAS find the disks and see the stored data? If not.... how can we get the data from the disks? Th...
Feb 22, 2016Guru - Experienced User
No, it will not. Your RND4210v3 is an NV+ v1, and it uses a different process and a different RAID organization than the ReadyNAS Pro-2.
If the NV+ is using XRAID and has only 2 disks installed, then you can connect the data disk (usually disk 1) to a windows PC via USB or SATA, and access the data with linux reader. http://www.diskinternals.com/linux-reader/
It is possible to mount the RAID volume in an x86 linux system - there is a guide here: http://home.bott.ca/webserver/?p=306
If you are intending to replace the NAS with a new OS6 model, you could contact support and see if they can assist in migration.
There are a couple of hardware options also:
You can also contact Netgear support and see if you can get a replacement power supply. Warranty was generally 5 years, so it may fact still be under warranty. I've been told that in some geographies Netgear might offer to sell a replacement PSU (I suspect it depends on local inventory levels). There are some replacement PSUs available from resellers, though some are very expensive.
It is possible to use a standard ATX supply (leaving it outside the NAS chassis), though you do need to change the pinout (best done with a 24-pin extension cable).
You could also find a used NV+ v1 and either migrate the disks to the whole unit, or swap the power supplies. If you have 2 disks installed, a used duo v1 should also work. If you pursue this option, you need to be very careful to get a v1 (sparc-based) unit. Also, some used ReadyNAS aren't functional, so there is some risk here.
- mdgm-ntgrFeb 22, 2016NETGEAR Employee Retired
If you go with an OS6 NAS e.g. RN314, then you should have a read of http://kb.netgear.com/app/answers/detail/a_id/29875/~/readynas%3A-migrating-disks-from-raidiator-to-os-6
That article explains what we will need for attempting data recovery from an array taken from a RAIDiator 4 (Sparc) system such as yours.
