ILoveYou
Oct 26, 2019Aspirant
RNDU2000 on OS6 : max hdd support, memory support, changing the ethrnet+USB card
Dear ReadyNas users, I have an old but still reliable RNDU2000 migrated to OS6 (it was delivered with radiator V4.2.19). Memory was upgraded using a 2Gb Sodimm Kingston KVR1333D3S8S9. Current conf...
Oct 27, 2019Guru - Experienced User
ILoveYou wrote:
1- disk capacity : was the limit of 4Tb disk removed with OS6 or is that linked to hardware ? in the compatibility list here : https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List (tab legacy), the max disk capacity is 4Tb. But a- we know the compatibility list is not exhaustive (exemple : the died disk is an ST3000DM001 which is not listed but worked perfectly) b- Netgear does not support RNDUx000 swithed on OS 6.
So If one of you has the experience with going above the 4TB limit I am interested to read his comments.
In the best case I would like to use 2x Seagate 8Tb ST8000VN0022 RAID1. Do you think it could be supported ?
You can certainly go with larger disks; the ST8000VN0022 drives should work. In fact they would have worked with 4.2.x firmware. I don't have an Ultra, so I haven't done this myself. But there are posts here from folks running 8 TB drives in the ultra - for instance here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/WD-Red-8TB-WD80EFZX-working-on-ReadyNAS-Ultra-2/td-p/1117514
With larger disks, the holes on the bottom of the tray won't all align with the ones on the disks. But some will align, and that's enough to mount the disk securely.
ILoveYou wrote:
2- And if possible will a memory upgrade bring significant improvment on data management ?
Currently shipping OS-6 ReadyNAS have at least 2 GB. It will run with less, but I'd still suggest maxing the memory as part of the conversion.
ILoveYou wrote:
Do you know if it possible to change that card to the one which was provided with the RNDU2000 next generation (If I remember correctly, it was 2x e-sata or 2x USB3 + 2x ethernet). If you have a netgear part number for that...
Netgear doesn't sell parts. I don't know if using a part from another ReadyNAS would work or not.
ILoveYou wrote:
4- (picture) last question : I recently had the following error in logs : "System: V+12 voltage in enclosure Internal is out of spec. (10.72 V)." Do you think it can be linked to the dying disk or do you think it is something linked to an issue with the mother board ?
The disk does use +12 of course. I guess there's a chance that it could be the disk, or possibly the power brick. But it could be an issue with the system board - so this error is concerning. Definitely keep an eye on it.
Note that you can migrate the disks to a newer OS-6 x86 NAS with no problem.
- ILoveYouOct 27, 2019Aspirant
Hello Stephen, thank you for your answer. Everything is clear.
I will probably try with seagate 8Tb and let know. (Hope it will work because they are quite expensive..)
StephenB wrote:
Note that you can migrate the disks to a newer OS-6 x86 NAS with no problem.If I understand correctly, a volume can be taken out of an OS6 Nas and insalled in an other OS6 NAS. Correct ? But I suppose we have to change all disks. Can it work for a 4 bays NAS, with 2 bays already installed, and we bring 2 new disks already formated ? I suppose not..
- SandsharkOct 27, 2019Sensei
Regarding swapping out the Ethernet/USB riser card, no, you cannot upgrade it. It does not include all the harware that supports the interfaces, it mainly provides the physical connections.
Yes, you can move all drives from one OS6 NAS to another, including legacy.
Under specific circumstances, you can move the drives from one NAS to another that already has drives installed and a volume exists.. I have gleaned this information form a number of experiments I have run, so I cannot gurarantee I have determined evey possibility.
- The volumes cannot have the same name. So, if you let XRAID format both volumes, they are both named "data", and you cannot combine them. There is no provision to re-name a volume.
- You also canot have any shares with the same name, but they can be renamed before the export to not match any on the other volume.
- I think user folders are exempt from item 2 because you lose the personal folders on the moved volume. While you lose access, the contents are not removed, AFAIK, so they just take up space unless you know how to go into SSH and fix that. Best to remove contents before the export.
- Ditto #3 for apps.
- You must do an "export" of the volume being moved before moving it. You set the other NAS to flex-RAID and then install the exported drives with power off. An import occurs at power-on. Note that once exported, a volume cannot again be made into a primary volume, it can only be added as secondary to another. (Well, there is a round-about way to make it one, you add it as secondary, then destroy the primary. Doing so does not recover apps or user folders that were once on it.)
Thank you for the detailed answers.
So no improvment possible on memory and connection side.
Next step for me is to try a ST8000NV0022 ; I will let you know if it works.
Hope the voltage issue is closed with the removed drive.
Have a good day,
