kennethlapensee
Jun 15, 2021Follower
RNDU2000 RAIDAR cannot find ReadyNAS on network when plugged into router, modem or a PC
RAIDAR cannot find my RNDU2000 no matter how I connect the unit by ethernet cable. I have tried plugging it into the cable modem, my router and my PC docking station.
Jun 18, 2021Guru - Experienced User
Did you configure a static IP address in the admin web ui?
When you plug it into your router, do you see it in the router's device list?
What is the ethernet LED status?
