jetheroheller
Feb 21, 2016Tutor
RNDU600 on OS6.4 suddenly reports "Cannot communicate with UPS UPS ()."
How do I troubleshoot "Cannot communicate with UPS UPS ()" I've been using this APC BACKUPS 1200XS UPS plugged directly into this NAS for about 5 years now, with no issues, including when I chang...
mdgm-ntgr
Feb 21, 2016NETGEAR Employee Retired
Which services and apps are you running?
If you download the logs what is the date in bios_ver.log ?
- pmkFeb 21, 2016Aspirant
Same problem with ReadyNAS 516 when I upgraded to 6.4.2. I get the error every 50 minutes (there seems to be an old thread about 6.1.9 with this issue).
Nothing changed except the version of firmware. UPS is APC Back-UPS RS 1500
I have a feeling that when I reinstalled the UPS it changed serial numbers but can't be sure - just looked different but I had not recorded the old one.
- mdgm-ntgrFeb 21, 2016NETGEAR Employee Retired
jetheroheller can you send me your logs (see the Sending Logs link in my sig)?
pmk as you have an OS6 NAS as opposed to jetheroheller's NAS which is a legacy one can you open an online support case and let me know the case number?
- jetherohellerFeb 22, 2016Tutor
logs sent as requested
- mdgm-ntgrFeb 23, 2016NETGEAR Employee Retired
pmk can you send in your logs as well?
- jetherohellerFeb 24, 2016Tutor
This is still happening, roughly every 50 minutes, or perhaps hourly on a random minute..
Also, plugging the APC XS1200 into my PC, or another NAS, and it is detected and 'communicates' fine, instantaly, so the wires and the device are probably ok.
Apps: Sickbeard, Transmission, Couch Potato, Plex
Services: SMB, AFP, NFS, ReadyDLNA, Rsync,UPnP, HTTP, HTTPS, SSH
date in bios_ver.log:
/sys/class/dmi/id/bios_date
10/03/2008also this is in the usb_devices.log
5-2 product=Back-UPS XS 1200 FW:8.g1 .D USB FW:g1 idProduct=0002 idVendor=051d devnum=3 speed=1.5
and this is the entire ups.log content (one line):
***** UPS *****
lots of these in system.log
NG2011 upsd[18206]: Can't connect to UPS [UPS] (usbhid-ups-UPS): No such file or directory
NG2011 upsmon[18211]: Poll UPS [UPS@localhost] failed - Driver not connected
