jetheroheller
Feb 21, 2016Tutor
RNDU600 on OS6.4 suddenly reports "Cannot communicate with UPS UPS ()."
How do I troubleshoot "Cannot communicate with UPS UPS ()" I've been using this APC BACKUPS 1200XS UPS plugged directly into this NAS for about 5 years now, with no issues, including when I chang...
Arquebus
Mar 04, 2016Aspirant
This seems like the same problem I experience. A few weeks ago I bought a new RN51600 NAS with an APC Back-UPS Pro 550. I've had several Netgear NAS boxes with different APC UPS'es before, and never had any issues with either of them. The last one was a ReadyNAS Pro Pioneer with exactly the same UPS. So I must admit I did not investigate any incompatibility issues with the UPS before I bought the new equipment...
After setting up and configuring the RN51600 with 4xWD RED WD60EFRX 6TB disks I connected the UPS with the USB cable as I was used to. Everything worked as expected, the UPS was recognized and it did show up as online with the estimated battery time. I did a quick test, removed power and noticed it switched to battery power as it should.
Now I decided to upgrade to the latest firmware version before putting the box into production. I was on 6.4.1 and upgraded to 6.4.2. After that the UPS was not recognized any more. I went through the usual reboot, reconnect, reset, power on/off routines, but no way.
Starting to read the docs, I found the following in the ReadyNAS OS 6.4 manual under UPS Configurations:
The ReadyNAS supports UPS devices managed over SNMP and UPS devices managed over a remote connection. It does not support monitoring over USB.
This was a bit surprising - is it really the case that UPS monitoring over USB is not supported any more? And what happened with this from 6.4.1 to 6.4.2? There is nothing mentioned in 6.4.2 release notes...
I have no apps installed and the following services enabled: SMB, HTTP, HTTPS, NFS, SSH, ReadyDLNA and Rsync.
