Sourii415e
Aug 19, 2022Aspirant
RNRX4420-100NAS Power Supply Replacement
I have an RNRX4420-100NAS (ReadyNAS 2100 [likely a v2]) that I have found that the power supply is bad on. I am seeing a lot of answers for the NV units but not this guy. Any help in finding this wou...
Sourii415e
Aug 20, 2022Aspirant
I can but the power supply at this point is long gone. However, I can confirm that there are no vent holes for a power supply with a fan. So if the NV has a fanless power supply that may very well be the power supply for this unit. it has 4 mounting points from the looks of it. Also, has anyone attempted to upgrade the RAM in one of these units with any luck?
Sandshark
Aug 21, 2022Sensei
While the power supply for the NV+ and other legacy 5-drive units is fanless, they have a baffle to deflect air from the main fan through them, and that airflow would be in the wrong direction for that chassis. That supply is basically a re-wired Flex ATX (mini ITX) supply with altered wiring (see ReadyNAS_PSU_pinout ), I think you'd need some sort of support plate for one of them to work.
