robmaz
Jul 26, 2017Star
RR3312 with UPS/RFC1628 MIB
Hello, trying to get my ReadyNAS 3312 under UPS control. We are apparently expected to somehow talk with Generex CS121 adapters (over the network) [1]. They are not in the networkupstools suppoted ...
Jul 26, 2017Guru - Experienced User
You don't see SNMP UPS in the UPS type pulldown?
But per the manual, this is only uses manufacturer specific MIBs (see page 195 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf ). Still one of the MIB options might be compatible.
- robmazJul 26, 2017Star
Yes, thank you, I see these options, but "ietf" is not in there, although mentioned in the compatibility list
and the snmp-ups manpage [1]. But then the manpage says the driver will probe the ups anyway and try
to autodetect the correct MiB. So what is the difference between choosing different manufacturers anyway,
as long as they load the snmp-ups driver?
- StephenBJul 26, 2017Guru - Experienced User
That I don't know (my UPS systems use NUT over USB).
It is honestly a bit stupid that all the other MiBs supported by snmp-ups can be selected from the list and the default "ietf", which is the standard rfc1628 MiB, is not in there. But it should also be trivial to fix that. How does one best send a feature request, is it enough to post it here and tag it accordingly, or is it necessary to try and open a support ticket for that?
