Shane88's avatar
Shane88
Rreadynas nv+ v2 Access After Changing Router
Hey.
Was hoping someone could help me understand this.
I can no longer access, read or modify my RND4000v2 after switching routers due to my old router dying.
The READYNAS NV+ v2 is currently displaying 192.128.1.1 i logged into my new router and switched the IP to match but that did not give me access. I can find it on RAIDer but it will not let me access the admin page (i tried this over wireless network and also by plugging the storage device directly into one of my laptops). Firmware is 5.3.13
Is there something really simple i am missing. I was able to access the storage from multiple machines right up until i switched routers.
Would appreciate some help.
Thanks in advance i hope.
Shane
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    Shane88
    Welcome to the community!
    It is possible that the ReadyNAS is assigned with a static IP address, that being said, performing an OS Reinstall should fix the issue (please check here for instructions on how to perform it).
    JeraldM
    NETGEAR Community Team
    • Shane88's avatar
      Shane88
      JeraldM thank you for your reply.
      Is this the only option i have? Will my data still be safe if i do the os reinstall?
      Thanks again.
      Shane
      • StephenB's avatar
        Yes.  It will reset the NV+ v2 to use DHCP and also reset the NAS admin password back to password. Other settings (and data) are left alone.
ProSupport for Business
