Pete10p
Apr 01, 2022Aspirant
RSYNc not working reliably since upgrading to 6.10.7
I use an old Netgear ReadyNas 102 as a backup from a Synology NAS. I have been using RSYNC reliably up to when I upgraded to 6.10.07 on the ReadyNas. Since the upgrade the backup fails. I have fo...
Apr 01, 2022Guru - Experienced User
I am not seeing this on my own backup NAS - which are also on a power schedule, and use rsync for backup. Backup jobs are run on the destination NAS (and the source NAS is not on a power schedule).
Are the backups being run on the Synology, or on the ReadyNAS?
One thing you could try is downgrading back to 6.10.6, and see if the problem resolves.
- Pete10pApr 01, 2022Aspirant
The backup is running on the Synology. All worked well until 6.10.7.
Ill wait to see if anybody has any suggestions before reverting back to 10.6
