Magic8Ball1
Jun 09, 2012Follower
SAS drive support
After a server upgrade at work I have Seagate Constellation ES drives spare - model ST32000444SS They are essentially 2TB 6gb 7.2k drives. It looks like they are not supported drives in a ready...
PapaBear1
Jun 24, 2012Apprentice
Well, now that I look up an image of one on Newegg, that is very true, the connector is totally incompatible. They will also not attach to any PC using SATA connectors. I now know what the SS at the end means and I did not catch that earlier.
Magic8Ball - by now you have probably discovered the connector problem.
