Roland111
Sep 19, 2019Aspirant
Sceduled Backup doesn't work anymore
Hi folks, I used to scedule a backup once a day from the readynas drive to a the external usb3 drive. This worked for years. Without any reason, the scedule doesn't start any more. Manual starting works fine, but the scedule doesn't start anything. The logs stay empty. Everything is connected right and working, as manual starting works. System time is correct and synchronized. The system just ignores the scedule. I triple checked all, can't find the solution. The backup job is a simple complete volume job. The destination needs no password, it is just as simple as it could be. Any ideas? Thanks for help.
What firmware are you running?
- Roland111Aspirant
Hi Stephen,
thanks for helping. The update button says system is up to date. RAIDiator 5.3.13
Roland111 wrote:
RAIDiator 5.3.13
Ok. So it is a definitely a v2 NAS. That's not a model that I own.
Are the logs empty even after the manual job completes?
Have you checked the USB drive for added files?
Have you looked in the full downloaded log zip file for errors (not just the backup logs)?
