BritBrat
Jun 14, 2012Aspirant
Seagate Barracuda LP ST2000DL003
Warranty may now only be one year. Seagate Barracuda LP ST2000DL003 2 TB 3 years Warranty readynas_hcl_disk - ReadyNAS NV+
Jun 14, 2012Guru - Experienced User
I don't think so. ReadyNAS systems are happy with mix and match. One risk with matching the drives is that if it turns out that there is a reliability issue with that model you are completely screwed. Mixing the drive models can hedge that risk.
BritBrat wrote: Your really need five drives of the same model if you fill your device.
If I drive fails you want the exact same model of drive to replace it.
Ultimately the length of the warranty is just a pricing decision. Longer warranties do not mean a product is more reliable. Seagate (and all vendors) bundle the expected warranty replacement costs into the drive price.
BritBrat wrote: But!!! If Seagate only have the confidence of a one year waranty would you trust the drive?
