SkyJawa
Jan 04, 2015Aspirant
Seagate ST2000DM001 Firmware Update
Looks like all my drives are on an older firmware and I have issues with 1 (different part no but same drive type) so was going to see if updating the FW fixes the problem. Is there a guide anywher...
Jan 05, 2015Guru - Experienced User
The procedure is not complicated if you can connect the drive to a windows PC. The hardest part is finding the correct firmware for your drives.
Apparently seagate often manufactures several variants for each drive (including some which have different number of platters). That is why they want the drive serial, and not just the model information.
