Herbert323
Nov 13, 2015Aspirant
Setting up a ReadyNAS 214
Hi, I have a new ReadyNAS 214 which I intend to use on a Mac network to stream iTunes and contain personal data. I am totally confused by the AFP, SMB, etc settings and wonder which I should set. In m...
- Nov 14, 2015
Just pick LACP with layer-2 hashing. FWIW, that is what the R8500 is using. That gives the most predictable results (not always the best performance, just the most repeatable performance).
Here's the way it works: The hashing is used by the NAS to decide which NIC card will send each data flow. It's basically like a coin-flip. So each data flow from the NAS to device X will always use only one NIC. Also, since this is an xmit decision, the router also is making this decision, and it could choose a different NIC for the return traffic.
Layer 2 uses the mac addresses of the NAS and the receiving device (which are hard-wired into the ethernet chips, and always are the same). Layer 3 adds in the IP addresses (which will vary if you use DHCP). Layer 3+4 adds in the TCP/UDP ports being used. That normally is only used if you are also using bonding in the receiving device.
There are a couple of implications.
One is that every data flow through the bond is limited to 1 gigabit. That's because every flow uses just one NIC in the bond. That is by design - the assumption is that the clients aren't using a bonded connection, and you don't want to overrun their 1 gigabit connection.
Second, if you sending from the NAS to 2 devices there is a 50-50 chance that the NAS will use the same NIC for their xmit traffic. If you look at both directions, there's a 75% chance that either the xmit or the receive traffic will share a NIC. So the bond is often underutilitized if you only have a couple of devices.
Since the different hashes give different answers to the "coin flip" you can sometimes get a better NIC allocation with a different hash. That can improve throughput with specific devices (when you only have a couple).
But as far as streaming performance goes, it really doesn't matter much. Streaming doesn't use as much bandwidth as most people think. Even full 1080p BluRay has a max of 54 mbits (8 megabytes per second). Even without bonding, that's only about 5% of the link capacity. And most HD streams aren't full BluRay - they are in the 1-2 megabytes per second range. So the hash isn't something you need to over-think.
Herbert323
Stephen,
Thank you for your very easy to understand response. Worked out well. One more question if I may, what setting should I use for link aggregation? I am confused by all the different hashes and choices offered. My Mai. Purpose again is not so much speed as streaming video.
Herbert
Nov 14, 2015Guru - Experienced User
- Herbert323Nov 14, 2015Aspirant
Thank you very much. That worked.
i am truly impressed with the ReadyNAS 214 in combination with the R8500. My WIFI and download speeds are fantastic.
Herbert
- StephenBNov 15, 2015Guru - Experienced User
Herbert
I'm glad you are up and running. The R8500 is a very nice wave-2 ac router, and of course just launched as Netgear's top-of-the-line home router. FWIW, I find that the 5ghz-1 radio gives the best speeds (somewhat better than 5ghz-2). Though 5ghz-2 is also fast.
If you haven't upgraded to 6.4.0 yet, I suggest holding off until 6.4.1 is released. The other option is to go directly to 6.4.1 beta (which is available in the forum).
