MacCollector
Dec 17, 2019Aspirant
Setting up email alerts for ReadyNAS Pro 4 with Comcast
I want to set up email alerts for my ReadyNAS Pro 4 but I get an error message: Unable to contact SMTP host. Please check your entry. All the info I put in is correct for Comcast. My comcast email address as User, my email password, smtp.comcast.net, port 465 and Use TLS is checked. What am I doing wrong? I'm using an ORBI router and a Comcast modem.
Perhaps try port 587 instead.
If the NAS is using a static IP address, then make sure you configured a DNS server.
- MacCollectorAspirant
I have a DNS Server assigned on my mac. On my NAS, the default gateway is the same as the DNS server on my mac. Is that what you mean? I'm sorry, I'm not a particularly savvy user.
The gateway should be the same IP address as your router (and that should match the gateway setting on the mac).
Is the DNS server address on the mac the same as the gateway address on the mac?
