Greysquirrel
Mar 29, 2020Aspirant
Setup wizard won't complete
Hi I recently had a problem with a full root drive that stopped my readynas from booting and failed to update to 6.10.3. I was able to remove some log files to bring the size down and update to 6.10...
Greysquirrel
Mar 30, 2020Aspirant
Thanks Marc
i fear I may have been over zealous in my cull of large files clogging up the root volume.
I have run systemctl list-units and I get:
mysql.service loaded failed failed
systemmd-modules-load.service loaded failed failed
i have done an os reinstall with no joy.
regards
Matt
Sandshark
Mar 30, 2020Sensei
Unfortunatel;y for you in this case, OS re-install tries to leave intact anything related to apps, so whatever is causing your problem is likely not getting erased.
I think you are to the point of either needing Netgear paid support (for which you'll need to be able to boot to Tech Support mode) or doing a factory default and re-building the NAS from scratch.
