HendrikH
Sep 02, 2017Tutor
SFP+ network card
Hi, is it possible / supported to add a SFP+ network card into a ReadyNAS 628X? thanks, Hendrik
- Sep 07, 2017
Hello HendrikH,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
Marty_M
Sep 04, 2017NETGEAR Employee Retired
Hello HendrikH,
As of the moment ReadyNAS 628X does not support SFP+ however this can be considered as a feature request and I would recommend to raise this to the Idea Exchange board of ReadyNAS. Adding a kudos would help and if the post does gather a lot of kudos Netgear may consider adding it in the future.
Marty_M
