Retired_Member
Mar 31, 2022Share Deletion issues
I'm trying to Delete a share via the Admin page on my RN314 but keep on getting the message, Unable to delete share due to Snapshot delete failure. Firmware is up to date and the Share Folder is empt...
- Apr 02, 2022
Retired_Member wrote:
My query is, if I return to Factory settings can I use my existing credentials on my Netgear and ReadyCloud Accounts to set the NAS up again fro scratch rather than set up a NEW account ?
After the factory default, the NAS admin password is set to password.
Do the setup by browsing to https://nas-ip-address/admin (using the real IP Address of course). No need to change your myNetgear/ReadyCloud account credentials.
Note you can save the configuration first from the system->settings page. After you do the basic setup on the NAS, you can re-install your apps, and then restore the configuration (the order matters). That can save some time.
Retired_Member
Apr 02, 2022Because of the issue I'm having unable to DESTROY a n empty Share, I was thinking of resetting back to Factory settings, I do realise all data will be lost but I've copied it all from my PC's to a couple of portable Hard Drives for safety. My query is, if I return to Factory settings can I use my existing credentials on my Netgear and ReadyCloud Accounts to set the NAS up again fro scratch rather than set up a NEW account ?
Apr 02, 2022Guru - Experienced User
