John245
May 06, 2021Tutor
Shares Gone 2120v2
Marc_V In the 4th comment of this post it was mentioned that a script is available to solve the issues of shares that are gone. https://community.netgear.com/t5/New-ReadyNAS-Users-General/Share...
- May 06, 2021
John245 wrote:
root@TEAPHOMENAS01:~# root@readynasos:#/ curl -s https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh | bash
-bash: root@readynasos:#/: No such file or directoryYou're supposed to just enter this bit:
The root@readynasos:#/ preamble was just representative of the normal Linux CLI prompt.
Did you use df to check the fullness of the root partition? You really should do that before running the script.
Also, as the web page notes, you need to be running 6.10.0 or later firmware.
John245
May 06, 2021Tutor
Thanks for the suggestions. But acces to root is denied. And running the script will tell that the filename directory is missing.
John
