John245
May 06, 2021Tutor
Shares Gone 2120v2
Marc_V In the 4th comment of this post it was mentioned that a script is available to solve the issues of shares that are gone. https://community.netgear.com/t5/New-ReadyNAS-Users-General/Share...
- May 06, 2021
John245 wrote:
root@TEAPHOMENAS01:~# root@readynasos:#/ curl -s https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh | bash
-bash: root@readynasos:#/: No such file or directoryYou're supposed to just enter this bit:
The root@readynasos:#/ preamble was just representative of the normal Linux CLI prompt.
Did you use df to check the fullness of the root partition? You really should do that before running the script.
Also, as the web page notes, you need to be running 6.10.0 or later firmware.
John245
May 06, 2021Tutor
Ok, So I logged in wit username root and the NAS admin password. I have access to the root folder, which is empty.
Script including result will look teh following:
John
May 06, 2021Guru - Experienced User
- John245May 06, 2021Tutor
StephenB Thanks a lot for your help, much appreciated.
The issue is solved. But the question is ofcourse how to prevent this in the future.
John
- StephenBMay 06, 2021Guru - Experienced User
I'm glad it's fixed.
Not sure how to prevent it (and of course we don't know what damaged the NAS configuration files). It's not something I've experienced on my own ReadyNAS.
I also not experienced it before. However when searching on the internet it seems that more people encountered this issue.
John
