  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello BSZ,
    Where do you see it changes? Is it on the admin page or the Windows explorer? Please also provide the firmware version.
    Welcome to the community!
    • BSZ's avatar
      BSZ
      Hi,
      The changes are visible in MS Windows Explorer .
      OS: 6.5.0
      • The short answer is "because it doesn't matter".
        Windows, and thus SMB as typically configured, is not case sensitive with regard to file or directory names.  "DVD" = "dvd" = "Dvd", etc.  This can cause issues if you use a case sensitive file system to create similary named files or directories with only different cases and then access though SMB, though I have not explicitly tried it on the ReadyNAS (I know to avoid it).
        SMB does have a case sensitive option, and early ReadyNASes had an option to turn it on (version 3.x, I believe).  That still causes issues, though different ones, and the option was deleted in later versions of the OS.  I do not know if it can be turned on via SSH, but I wouldn't recommend you do it, even if you can.
ProSupport for Business
