garbea
Jan 13, 2019Aspirant
Shares showing on network,but cannot access data
Yesterday i had 1.87tb of space left of storage,today i mistakenly turned on snapshots , now its showing storage full and will not let me access shares.The shared folders are showing in windows e...
Jan 14, 2019Guru - Experienced User
Can you download the log zip file?
If you don't have a backup you should contact paid Netgear support via my.netgear.com
- garbeaJan 14, 2019Aspirant
hi,
l have downloaded the log zip file.
i do have a backup of the data,should l just format the drives on the readynas and then replace them for larger drives?
- StephenBJan 14, 2019Guru - Experienced User
garbea wrote:i do have a backup of the data,should l just format the drives on the readynas and then replace them for larger drives?
That's what I'd do.
But if you already have the larger drives (or can get them quickly), then just rebuild the NAS with the new drives in place.
