fesh
Jan 29, 2012Aspirant
Silent NAS wanted
I need to put my NAS in my living room. So it must be as silent as possible. Thus I don't want a RAID configuration where all disks are spinning, but a JBOD configuration where unused disks spin down...
PapaBear1
Jan 29, 2012Apprentice
First - all of the 4 bay units except the NV+ v2 have virtually the same hardware. They all have the 92mm case fan and an internal fanless PSU. The NV+ v2 has an external power brick as do all the 2 bay units. All of the fans vary their speeds based on heat conditions.
In the living room next to the TV is a poor location, for if after a bit, you will walk up to any flat screen TV you can feel the heat emanating from it. I have a 52" Plasma that is now 6 years old and the area around the TV is several degrees warmer than the rest of the room which is warmer than the rest of the house.
You would be better off to place the NAS in another room with an ethernet connection between the NAS and the living room if at all possible. Except for the Time Machine backing up your desktop/laptop, I don't see any provision for data protection. If you load up two separate disks with movies, and one of the disks goes down, then you have lost them unless you still have the original DVDs. Then a single disk for music and general files. If the general files are not on the desktop/laptop backed up by Time Machine, they should be.
