fesh
Jan 29, 2012Aspirant
Silent NAS wanted
I need to put my NAS in my living room. So it must be as silent as possible. Thus I don't want a RAID configuration where all disks are spinning, but a JBOD configuration where unused disks spin down...
fesh
Jan 30, 2012Aspirant
I drilled a hole in the wall and ran some cables thru.
PapaBear wrote: OK, my question is what connection will there be between the NAS and the device playing the movie (AppleTV or whatever)?
Right, not for HD. I used to use WLAN for streaming SD videos to my Macbook, but for HD you definitely need Cat5 or better.
If you are planning wireless, I'm not sure that even Wireless N will have enough bandwidth to do it.
I was hoping the NAS could do that, with a simple Behringer U-Control UCA202 USB sound box attached to the USB2 port.
In the same vein, you will have to have some device between the NAS and the receiver to play the music.
Or probably I just use my retired PowerBook G4 Titanium for that - just need to replace its (noisy) internal PATA disk with an IDE->CF adapter and install MacOS 10.5 with iTunes on a 8GB CF card (noiseless), hook it up to the NAS and just mount the music disk... At least then I can control it with my iPhone remotely.
I've just got confirmation (usenet) that some Synology boxes do that. The poster only owned a 2-bay box (DS-211), so I don't know whether the 4-bay boxes will do it...
I am also in the mind that either all the disks will be spun down or spun up together, not individually. I don't know of any box that will do that.
Hopefully it should NOT be turned off but only sleeping (fan off, processor off, RAM powered), and not boot (30-60 seconds) but only wake-up (2-3 seconds).
Also, the drives spinning up is NOT Wake On Lan, that term applies to a box that is physically turned off but then turns on and boots when accessed.
I would only allow booting if it takes less than 5 or at max. 10 seconds, otherwise I'll buy another box!
Problem is that most bigger NAS boxes are only thought of for (small) business, where performance is important and saving power is not, while the home user is thought to use a 1-bay or at most a 2-bay NAS. But with some hundred movies in the collection plus movies plus TM backup, I definitely need at least 4 drives - but still want the NAS to be optimized for saving power and being silent and absolutely don't care about speed as long as it's fast enough for streaming 1 HD movie plus 1 Timemachine backup concurrently.
In Spin Down, the box is on and the fan is on. Only the drives are stopped. When you access the unit, even going into Frontview and accessing any section beyond the home page will do it, the drives spin up. The LCD panel will come on and say spinning up. My backup unit is set for spin down after 90 minutes so it is only up during the time it resyncs to my primary NAS during the wee hours of the morning.
Spinning all 4 drives or only 1 should make quite some difference on the electricity bill. And be more quiet.
Netgear should wake up. I think every home user would want to save energy, and have less noise.
