physicsguy1
Jul 30, 2011Aspirant
Simple question for 600-A rebuild
If I want to write the Radiator 4.1.7.7 image directly to CF with Mac dd, do I write it to the entire physical CF drive (e.g., /dev/disk1) or to a partition on the CF drive (e.g., /dev/disk1s1). If t...
mdgm-ntgr
Jul 30, 2011NETGEAR Employee Retired
You need to clone the 4.1.7 image onto the CF card, so I'd try writing to the entire CF drive.
There used to be an old FAQ and before that a wiki . I think what you linked to was probably an old help section that was replaced by the old FAQ.
