PeterPJ
Oct 06, 2021Aspirant
SMB Protocol
Hi I using a program called GoodSync to sync data from my Windows 10 Pro pc to my ReadyNAS 312 the backup stopped working last week when GoodSync updated their program, GoodSync support say they hav...
- Oct 07, 2021
schumaku wrote:
Curious where the idea comes from that you have to play with the (Windows native) SMB client and/or the SMB server (SAMBA here).
When quickly reading over the GoodSync News for Windows, one can find recent update notes like these: SMB client: continue work on our own native SMB client, both for SMB v2/v3 and SMB v1. This does not read like it requires an SMB 2.x server only.Also, SMB FS: Added option to use New Sib-SMB FS or Windows-based SMB FS to Program Options is in the release notes for 11.8.3 here: https://www.goodsync.com/news-windows
So you can apparently use the Windows stack if you use that option.
Oct 06, 2021Guru - Experienced User
schumaku wrote:
ReadyNAS OS 6 does support for a longer time SMB protocol 3.1.1, has fall-back options for SMB 3.0, SMB 2.1, SMB 2.0, and still can deal with SMB 1.0 for legacy applications (which includes user-space Apps on mobile devices!)
I just want to add that this means that the NAS supports SMB 2.x connections by default, so you shouldn't need to change that.
schumaku
As we talk of a Windows 10 Pro system, we can assume it does negotiate to the highest SMB dialect available on both sides - what would translate to establish some SMB 3.1 or SMB 3.1.1 connection.
- StephenBOct 07, 2021Guru - Experienced User
