darthy's avatar
darthy
Apprentice
Aug 10, 2019
Snapshots have stopped
Hi, I have had my ReadyNAS 314 for quite a number of years with Snapshots enabled and have only had one issue during all that time which the ReadyNAS team resolved for me after a firmware update (2 -...
  • StephenB's avatar
    Aug 13, 2019
    The default setting was 95%, but they might have dropped it down to 90% after that (my own NAS is set to 90).   If yours is set to 85%, then you probably adjusted it.
    But I think that explains it.  Your system is over the threshold (~86% full based on your earlier post).  The system probably started deleting the oldest snapshots a while ago - bringing the free space back up to 85%.  But your main volume continued to grow and eventually the system deleted them all.
    So the solution is to expand the volume.  Though you could bump the setting up a bit for now, I wouldn't go above 90.
ProSupport for Business
