phil060506
Feb 27, 2024Guide
Snapshots on RN528 OS6
I am about to do a full Reset to Factory on my RN528 (with 8x8TB Ironwolf drives). I will be using the out-of-the-box RAID6 config that is created by default. I want the new configuration to be su...
- Feb 28, 2024
OK, that is the page I thought you were referring to. Nothing there tells you what the snapshot schedule is. It shows how many snapshots currently exist.
To delete snapshots, use the gear icon for each share and select "recover". Then when the snapshots are displayed, right-click on each and select delete. It may take some time for the snapshot space to be recovered (assuming they really are taking up much additional space).
Sandshark
Feb 27, 2024Sensei
Yes, you just set the snapshot frequency to "Never".
phil060506
Feb 28, 2024Guide
Thanks for your quick reply... I assume you mean in the settings for each share, is that right? When I try to do that the snapshot frequency does not change as shown in the share status screen
- SandsharkFeb 28, 2024Sensei
I can't see your screen shot until a moderator makes it available. But the "Shares Status" screen, if I understand which page you mean by that, doesn't show the frequency of snapshots, it shows how many are already made. If you turn off snapshots, that doesn't remove existing snapshots -- you have to do that manually.
- phil060506Feb 28, 2024Guide
Many thanks
