Coffin_Jim
Mar 14, 2019Aspirant
Snapshots showing in GUI but not in share
We previously had an issue after updating the firmware to 6.9.5 that caused the share to be "unlinked" from the GUI. To resolve this, we created a new share and copied the data over.
Now - for ...
- Mar 18, 2019
Looking over this, I think we never used correct full path when triying to delete.
This should work.
# btrfs subv delete /data/Shared_Data/.snapshots/12260/snapshot
Coffin_Jim
I tried several different variations of the following
# btrfs subvolume delete -c /Shared_Data/.snapshots
Also, when browsing through windows i can see the .purge folder but not .snapshots
Mar 14, 2019Guru - Experienced User
Try
# btrfs subvolume delete -c /Shared_Data/.snapshots/12260/snapshot
- Coffin_JimMar 15, 2019Aspirant
No joy i'm afraid:
Last login: Thu Mar 14 14:55:38 2019 from jca-01ict01pp root@Reflections:~# btrfs subvolume delete -c /Shared_Data/.snapshots/12260/snapshot ERROR: Could not statfs: No such file or directory root@Reflections:~#
Also, as previously mentioned - the snap shot directory does not show up in file explorer:
- StephenBMar 15, 2019Guru - Experienced User
It doesn't for me either. Is your share configured set to "Allow Snapshot Access"? Mine are not - though I do enable "Allow access to Windows Previous Versions".
But you can't delete the snapshots from Windows, even if you can see them.
Coffin_Jim wrote:
No joy i'm afraid:
Odd. What happens if you try to browse into the folder?
One approach is to use the "nuclear" option - delete the volume (or reset the NAS) and restore the data from backup. Painful, but it will resolve it.
- Coffin_JimMar 18, 2019Aspirant
StephenB wrote:
Coffin_Jim wrote:
No joy i'm afraid:
I'm trying to avoid this if possible as 6tb will take all weekend to restore.
