Coffin_Jim
Mar 14, 2019Aspirant
Snapshots showing in GUI but not in share
We previously had an issue after updating the firmware to 6.9.5 that caused the share to be "unlinked" from the GUI. To resolve this, we created a new share and copied the data over.
Now - for ...
- Mar 18, 2019
Looking over this, I think we never used correct full path when triying to delete.
This should work.
# btrfs subv delete /data/Shared_Data/.snapshots/12260/snapshot
Hopchen
Mar 18, 2019Prodigy
Well, it is difinitely a snapshot.
Sorry, I should have specified that full path before.
Can you cd into the snapshot by:
# cd /data/Shared_Data/.snapshots/12260/snapshot
Do an ls -lah once in there. What do we see?
Also, you defintely cannot remove it? Just to double-check:
And if you try and show the properties of the snapshot?
# btrfs subv show /data/Shared_Data/.snapshots/12260/snapshot
Cheers
Hopchen
Mar 18, 2019Prodigy
This should work.
- Coffin_JimMar 18, 2019Aspirant
perfect! Snap shots are now showing zero. I will run another balance just in case as i found the snapshot size increased when i initially did this.
Thank you for all your help, it is much appreciated!
- HopchenMar 18, 2019Prodigy
Super :)
