module12
Dec 13, 2015Apprentice
Snapshots (Windows Previous Versions)
Hey, Just got a RN204 and playing with the snapshot feature. Watching this video suggests you can access snapshots on the ReadyNAS from the Previous Versions tab directly in Windows: https:/...
andrewking2
Dec 14, 2015Aspirant
Have you checked off the "Allow Snapshot Access" under the Snapshot setting on the share properties on the ReadyNAS? If you don't, it will make the snapshots, but Windows can't see them. As soon as you enable and apply they will all show there.
It will have a visible "snapshot" folder inside the folder, and the previous versions will work as it used to. This is on my Windows 10 box at home,
- module12Dec 16, 2015Apprentice
Yes, I've got allw access to snapshots turned on.
I worked it out anyway. If you re-direct a folder, say Documents to the NAS, previous version tab doesn't work. If you browse to the share via \\nasname\share it works OK.
Wierd...
